charat wrote:cool. thanks. i ll just use that as a template then since i have all teh tubing already. maybe ill make a write up for it XD
You can look at the pictures of the cage in my hatch. They are on like the 6 or 7th page. Your car is a coupe, but the same basic design is the same.
You likely wont need nearly as many braces as I because you probably dont need an FIA spec cage, but it could be helpful.
I will say, that no matter what you do. Push the roof bars as close to the edge of the roof as possible. There is very little head room to start with, and cage tubes, and skulls dont get along.
