xprogue wrote:wow nice Forum ~
xprogue wrote: Now i am about to choose a hitch, here is some hitch that i found from the forum and ebay, dont know what is my best choise. [snip] Also i went to uhaul today and they quote $144 for the hitch and $17 for the wiring( )? Dont know if i should belive them.....
As long as you get a quality Class III hitch they will all perform the same. The benefit of shopping around is to save $$$. Price varies because some are painted, some have a powdercoat finish to protect it from rusting. Some have sealed end tubes to prevent internal rust. Some "include" the wire harness. etc, etc.
As far as the UHaul install... you could probably save about $20-$40 by buying one and installing it yourself but you have to ask yourself if it's worth the hassle. Where you really come out ahead with the UHaul install is with the hitch wiring. UHaul will splice into your existing wiring and provide the connector needed for connection to their trailers. $17 for them to do it or $40 -$50 for a plug-and-play harness you'll have to install yourself.
UHaul has been around for a long time. A quote is a quote, you can believe the quoted price. The fact is... they install quality hitches at a very attractive rate. They don't do this because they want to give you a great deal on a hitch, they do it because they want to rent you a trailer (which is where they make their money)They've been installing hitches and wring them up for decades. If there was a problem with their hitches falling off, breaking, inferior products, causing accidents etc... they wouldn't still be installing them today (they'd have been sued into bankruptcy) The only concern you might have is whether or not your particular UHaul installer is gentle with his tools around your new Rogue. The last thing you need is a grease monkey leaning against your car with a screwdriver in his pocket... SSSSScratch! If you stand and watch them do the install you should be okay. (As with any mechanic, they will generally be more careful if they know the owner is watching them work)
FYI: I called my local UHaul...told them I had a Rogue... and asked if they could tell me anything about what hitch they would be installing. They told me they would have to call back. A guy called me, ironically he said they would be installing a Curt Model 13185... a Class III hitch. Anyway, here's the scoop on UHauls hitch for the 2008 -2009 Nissan Rogue:
U-Haul Hitch # 78277. This is a Class 3, 3,500 lb, 2" receiver hitch
http://www.capandhitch.com/PDF...S.PDFo ... x?pn=13185
