Ok.
I am totally impressed with the General Tire Altimax 365AW tires.
We finally had a bit of snow here and I had a chance to drive around in the snow, and these tires really held their own.
1) Spring - Ok. I didn't have these tires on my Rogue in Spring. But I did just get them on my Dodge Grand Caravan in March. In the wet weather they really moved the water aside well. And it really felt like I was sticking to the road. Even when the temperatures would get cooler.
2) Summer - Ok. I didn't have these tires on my Rogue in the Summer. But I did have these tires on my Dodge Grand Caravan all summer. And they rode really well. Stuck to the road no matter what. Even going through deep puddles, these tires just moved the water aside and drove straight through the water. The gas mileage did not seem to change much, if any.
3) Fall - This is when I put these tires on my Rogue. These tires really held well on the road. And when it got cooler (down to 1-2 Degrees C) the tires did not get stiff. They really seemed to stick to the road better than a standard set of All Season tires. Even when the it was 1-2 Degrees C and the roads were wet, these tires really stuck to the road. When driving around these cold / wet conditions with All Season tires, I would get used to the tires slipping out a bit. And just accounted for that driving around. But these All Weather tires stuck a lot better in cold / wet weather. (If I decide to get winter tires again for this car or another . . . I would probably also get All Weather tires for the warmer months [instead of All Season] . . . so that during the overlap seasons [Spring and Fall], when the temperatures are down around 1-2 degrees and the roads are wet that I don't slip around as much. To me, it was that much noticeably better.)
4) Winter (so far) - So we really only had 2-3 snowfalls.
The 1st one it was a light dusting. The snow was on the roads, but was gone in about 1/2 an hour. But I had to drive around that morning. It was cold 1-2 Degrees C. And the tires really felt like they were sticking to the bare road (even in the cold.) The light snow drifts, it had no problem with at all. And I did find a small patch of ice covered in a bit of snow, so while I was driving over it I hit the brakes to see how the tires reacted. The tires slipped . . . but that is to be expected. It was ice covered with a light drift of snow.
But with the ABS kicking in, these tires stopped in a reasonable distance. I was trying to imagine going over the same snow covered ice with dedicated Snow Tires . . . and I assume I would have stopped a bit shorter, but the dedicated Snow Tires would have also slipped. But I was totally comfortable with what the General Tire Altimax 365AW tires did. When there is a chance of ice . . . you should be leaving extra stopping distance as a general rule anyway.
We finally had a bigger snowfall on Dec 23rd (2022). Lots of accidents on the highway. And the highway got shut down west of us. I was at work when the snow started. And had to drive through the start of the snowfall. Living near the city and near main roads, this is probably the most snow I would have to drive through. Snowdrifts were sometimes 5-6 inches. And as I got further out from the city the highway was not freshly plowed. So the center lane was snow covered. And there were only tire tracks cleared on the outside 2 lanes. I kept my speed down. Maxing out at 70-100 KM depending on road conditions. But I noticed that the tires still felt nice and soft. Where they hit pavement, they really stuck. And when driving through the 2-4 inches of snow, the tires seemed to move the snow out of the way really well. At 5-6 inches, the car would shift as the snow moved around. But I always felt in control. With all-wheel-drive . . . I would just aim the tires in the direction I wanted to go, press the gas a bit, and I'd go in that direction. These tires, working with the all-wheel-drive had no problem helping me go in the direction I wanted to go.
Conclusion:
I was really impressed with the General Tire 365 AW.
I'm glad I got them on the van. I'm glad I got them on our Rogue.
My dad needs new tires for his car, and I told him that his next set of tires should be All Weather. If I can get the General Tire 365 AW for his car I'm going to get them. (But there is a chance it will be sold out. I already talked to the place I go to get tires. If so . . . we might get a different brand of AW tires. We'll see. But it's going to be AW tires we get.
