Rogue 2017 questions for trunk
Robertstrick
Car: BMW 328i F30
Nissan 350Z
Hi all! in my Rogue 2017 (restyling) There was a problem with the trunk, it just stopped functioning! I showed the car to a local mechanic, he said that the problem with the electronics did something and the trunk worked, but only 2 times and again the same problem .. Who faced this problem? maybe you need to change the lock?
If I pry it from the salon with a screwdriver, then the trunk opens, but I need to work very hard to do this..
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
What codes did they pull up from the ABD system? The most common failures are the half-latch switch, which requires replacing the lock assembly, or a bad spindle motor/sensor, which means replacing one of the lift cylinders. In either case the system has to be reset with a scanner after the repair. If you post the codes here, we can help you sort it out. The dealer did the right thing to try a simple code erasure and reset, often people get debris stuck in the mechanism or there's a glitch from a low battery and the error doesn't reoccur. Since it did recur, the new codes will tell you where the problem is.
Robertstrick
Car: BMW 328i F30
Nissan 350Z
I didn't know what the mechanic was doing, so I can't say the error codes, but if you say that the mechanic did everything right, it might make sense to turn to him again, thanks! I think that the problem is still in the castle itself..
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:welcome:
Please use the SEARCH feature before creating a new topic.
Power trunk hatch will not open
Return to “Rogue Forum”
