Rogue 2015. Passing cables from interior to engine compartment.
Barenca
Car: Nissan Xtrail 2015
Hi, I want to install an aftermarket front camera and I want to pass cables from interior to exterior (engine compartment). Does anybody know how to do this? (A place where It is easier to pass cables).
Any help will be appreciated. Please share photos.
Thanks
sonudel
Car: 2015 Nissan Rogue SV AWD
and
Old and Sweet 04 Nissan Altima SE V6
I am not sure why do you want another camera as far as I know my Rogue SV with premium package has the front camera as well as back camera. The front gets activated only when you are in the park/drive mode and press the camera button. The back is activated when you are in reverse mode. Hope that helps and save you some money :)
Edit 1: I just realised you have a Xtrail which I have no idea about the front camera. I just assumes as this is in Rogue forum you are asking about Rogue. however you are welcome to check on the xtrail as well.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to the Rogue forum on NICO!
Have you looked over the FSM? There's a link in my sig line. I'd hazard a guess that it's not too dissimilar to the way it would be done on a first gen model. Please check this link: 08-13 ROGUE DIY REPAIRS & MAINTENANCE, FAQ & INFO, TIPS, etc. Scroll down to the audio upgrade section.
Barenca
Thanks you guys.
@RogueOne I have read some documents of FSM but I have not been able to find a hole/grommet for doing this.
@sonudel, thanks. The trim level of my Xtrail does not include the front camera, It just includes the rear camera. Acording to the FSM, XTrail (I could find this manuals -spanish) and US Nissan Rogue 2nd Gen are almost the same. There are some minor differences on color cables and harnesses.
I will install a front camera with an electronic circuit for 15 seg delay (after the reserve signal has been change off), I will be using an aftermarket radio (Pioneer AVH-X2750BT). Once I success I will share some photos.
Meanwhile, for all of those that want to run a cable through firewall, this thread could be useful (not so much details but could help)
2014-nissan-rogue-adding-subwoofer-ampl ... l#p6637583
Regards
Sorry for my English
JC Rogue
Has anyone found an easy way through the firewall for wiring on a 2nd gen rogue?
I hat to drill a new hole if one is there.
Rogue One
2022 Honda Pilot SE
JC Rogue wrote:Has anyone found an easy way through the firewall for wiring on a 2nd gen rogue?
Welcome to NICO!
--------> READ BEFORE CREATING NEW THREAD! <--------
We have an incredible SEARCH feature on this forum. Merged with existing thread. Please take a few minutes to read these topics:
how-to-make-your-rogue-go-thump-thump-t ... 71349.html
getting-wire-through-firewall-t587368.html
Return to “Rogue Forum”
