Ivan on one of the pistons there was significant blueing and friction on the wristpin. It's in a circular pattern and doesn't have alot of strike damage from when the piston decintegrated. From the violence and the bending seen on some of the rods (smooth bending), it seems likely that one or more of the wristpins could have seized, caused the small end rod bearing to seize from the added stress, and ultimately rod failure. That would cause the rod to snap, and I'd imagine the piston would also shatter.IvanAtSPRacing wrote:Fiz, pivot the rod back and forth on this assembly how does it feel? Is it nice and loose or does it kind of bind? Watch the wrist pin when you move the rod back and forth. Does the wrist pin move with the rod or with the piston? Can you slide the rod side to side on the wrist pin?
What concernes me is why the rod caps came compleatly off. I am wondering if there was an issue with the rod bolts. Most of the time when you break a rod, you end up with the big end still stuck to the crank (like your #2) Can you find the rod bolts from 1, 3, and 4? Take some pix.
On one of the rods there is some casting text down the side of the groove. The final Nissan logo appears to be stretched and drawn at an angle. This could elude more towards snapped rod as a result of some other friction source perhaps.
More about the rod caps, if you look at the destroyed rod, the lower cap is bowed outwards and the upper cap is coned. This obviously shows where the rod bolts attempted to keep the assembly intact but there was a very strong resistance force (blueing of the bearing also shows high frictional load). There is a disparity between the planes when you look at the upper and lower connection points for the rod bolts. While they have excellent torsional and linear rigidity the rod bolts are not made to withstand a sheer load from the caps migrating.
My .02 cents, alot of it could be speculation but sometimes it's something to think about.
