RHD RB30 Build - update 6/20/13
julio
Car: RB26 AWD converted S14
Whats the wastegate pressure with the boost controller off? Could be that your wastegate spring is too weak and you need to increase it. I'm sure that big turbo needs all the exhaust it can get to make boost.
J2fast
Car: 240sx
julio wrote:Whats the wastegate pressure with the boost controller off? Could be that your wastegate spring is too weak and you need to increase it. I'm sure that big turbo needs all the exhaust it can get to make boost.
it makes 19-20psi with no boost controller on it.
RRRRB
Car: 98 RB powered S14
take the lines off the wastegates let them stay shut the entire time, boost on it higher up in the rpm range and see if it makes more boost..
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
I am running the R230 with the 4:11 richmond gears. It was nice on the rb26 but with the rb30 you really gotta petal it alot more to keep from shredding the tires. Then again with the 3.69 gears i was pretty much never coming out of 2nd gear in town. haha.
J2fast
Car: 240sx
RRRRB wrote:take the lines off the wastegates let them stay shut the entire time, boost on it higher up in the rpm range and see if it makes more boost..
when i took the lines off the wastegate it only boost about 18-19psi.
RRRRB
i mean all the lines.. so there are none going to it
julio
Are you saying 18-19psi with no lines hooked up to the wastegate or just bypassing the boostcontroller?
J2fast
Car: 240sx
Are you saying 18-19psi with no lines hooked up to the wastegate or just bypassing the boostcontroller?[/quote]
well when i didnt have any lines in the wastegate it was about 15-17psi with the lines hooked up but controller off it gets 18-19psi
julio
Julio wrote:Are you saying 18-19psi with no lines hooked up to the wastegate or just bypassing the boostcontroller?
J2fast wrote:well when i didnt have any lines in the wastegate it was about 15-17psi with the lines hooked up but controller off it gets 18-19psi
Unless you have the top port hooked up, there is no reason why it should boost more with the lines hooked up vs. not. Considering your car only boosts 15-17psi with no lines attached at all (where it should over-boost to 30-40+psi), I would say you are missing the fire ring, loose v-band clamp/blown WG gasket, or have a very, very, very weak wastegate spring.
J2fast
Car: 240sx
Unless you have the top port hooked up, there is no reason why it should boost more with the lines hooked up vs. not. Considering your car only boosts 15-17psi with no lines attached at all (where it should over-boost to 30-40+psi), I would say you are missing the fire ring, loose v-band clamp/blown WG gasket, or have a very, very, very weak wastegate spring.[/quote]
whats the fire ring? its a v-band setup
julio
The fire ring slips inside the WG vband flange and serves as the seat for the WG valve. Without it, exhaust would flow out of the wastegate even when not under boost.
J2fast
Car: 240sx
julio wrote:The fire ring slips inside the WG vband flange and serves as the seat for the WG valve. Without it, exhaust would flow out of the wastegate even when not under boost.
Oh yea I have that in place. I replaced a dried out hose from the wastegate n now it will go to about 27-28psi but not 30's. when u said that if no lines are hooked up its suppose to over boost right? But how if it only going by spring pressure
RRRRB
If there are no lines going to the gates.. there is no pressure there to open it.. the pressure from the turbo has to over come the springs in the gate..
J2fast
Car: 240sx
RRRRB wrote:If there are no lines going to the gates.. there is no pressure there to open it.. the pressure from the turbo has to over come the springs in the gate..
But I thought once it hits enough flow that pushes the spring up then that's all it can hold which is why U have to get a boost controller to add boost
RRRRB
Yes exhaust will eventually open the gates.. but not till very late in the rpm range... generally a 1:1 ratio is normal
J2fast
Car: 240sx
RRRRB wrote:Yes exhaust will eventually open the gates.. but not till very late in the rpm range... generally a 1:1 ratio is normal
But if it's like a 20something psi spring in there it wouldn't boost to 30-40psi tho would it
RRRRB
Have you ever blew a wastegate line off? Boost generally goes to the moon before it hits boost cut.. hopefully you hav e one set up..
Sounds to me you haven't checked everything thoughly.. a boost leak test would have found your wastegate line leak etc.. your missing something..
J2fast
Car: 240sx
RRRRB wrote:Have you ever blew a wastegate line off? Boost generally goes to the moon before it hits boost cut.. hopefully you hav e one set up..
I have blown a few off but I just don't get as much boost when mines pop off. N last night I replaced all my vac lines.
julio
It sounds like you just need a stiffer WG spring.
J2fast
Car: 240sx
julio wrote:It sounds like you just need a stiffer WG spring.
Well I upgraded 3times already but the part that don't make sense is no boost controller it gets 18psi with boost controller max it gets is 27psi
boostedh23a1
Car: Datsun 240Z
Datsun 280Z
I would think your controller is maxed out too, unless you have a dual port controller.
J2fast
Car: 240sx
so i FINALLY found the problem......... the stupid intake manifold under the bottom has a bunch of air coming out from it at only 7psi on the boost leak tester. so now im going to weld the two pieces together than i shouldnt have this issue again. thanks for all yalls help on brain storming.
RRRRB
glad you found it... lets see some numbers on that comp turbo!
Booztd 3
Car: 1990 Nissan 300ZX TT
Don't forget to dial the boost back down, lol
J2fast
Car: 240sx
Booztd 3 wrote:Don't forget to dial the boost back down, lol
I know ive been thinking should I change the springs again. But idk I guess I'll see how much it hits first then change it if need be but aiming for 36psi
Booztd 3
Just setup a fuel cut for a pre-determined boost threshold. Your teeth might meet your steering wheel but at least you'll save your engine.
J2fast
Car: 240sx
Booztd 3 wrote:Just setup a fuel cut for a pre-determined boost threshold. Your teeth might meet your steering wheel but at least you'll save your engine.
well i wish PFC had those types of options to control that but......
J2fast
Car: 240sx
so a quick update
i took the head off to take it to the machine shop to fix the shims issue and found that th valve guides are bad. how much power is at lost usually? and while its out should i do valve angle job? or anything like that?
RRRRB
Why did you pull the head for a shim issue?
Are the valve guides in the head now the original OEM?
I wouldn't mess with the valve seat angles unless the guy doing it knows RB heads and what they like..
Was the head previously ported or modified?
J2fast
Car: 240sx
RRRRB wrote:Why did you pull the head for a shim issue?
Well I pulled the head off so they can make the valves perfect. But the guides where original. The head was ported mildly. But was thinking to do any small thing to do why it's out
