WDRacing wrote:Easiest to leave the existing sensor in and weld the new O2 bung in, but I do believe it has a hooup for the ecu if welding the bung isn't an option.
WD
Yes, it has a pre-programmed narrow band output 1 that you can hook up to your existing o2 harness.
I just tapped into my ecu's wiring harness so I can unplug the stock o2, and use the wideband + the wire tap for a complete setup. My check engine light did come on, however, and I don't know if it was due to the ecu detecting no load on the heater wires, or if the ecu detected an incorrect voltage.
