Oh by the way anyone that is trying to do this, you can achieve it without dropping the transmission, Just loosen the back bracket with the transmission on a jack. then slowly lower it till it cant go any lower because of the exhaust. and to get the old switch out this sounds like a pain but after a bunch of trial and error this one worked. Take the blade of a Hack saw and cut the rear of the old sensor off so you can get a short socket on it.takes a while but its not to bad. Goodluck
