Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri Mar 22, 2013 6:17 pm
That's more indicative of a vacuum leak. The way you tell if it's a vacuum leak is by spraying some starter fluid around the engine bay, and seeing if the idle changes when you spray a particular spot. Key areas are around the plenum, any vacuum hoses, and intake piping past the MAF.
If the WD-40 works, then obviously you've solved your problem. If it doesn't, I'd try the starter fluid, as it's easier than cleaning the IACV.
