Speaking of inputs, did you happen to try what I said? I'm curious as to how it turned out...240pav wrote:haha wow ok this is getting way out of hand im guessing u want that to prove me wrong huh ? sorry im not going through that bit of work to make u happy. im done with this alreadyall i wanted was input about a few things thats all
Quote »Even though your coolant reservoir is full, the radiator may not be drawing the coolant from it for one reason or another (loose cap or leaky seal around water pump, for instance). Start the car cold with the radiator cap off, and let the engine warm to operating temperature. Once the thermostat opens up, see if there is coolant visibly flowing through the top tank. If not, first give it a couple small revs and see if you can see short rushes of coolant. If you still don't, carefully fill the radiator until you do. This is how I solved an overheating problem of mine when coolant was leaking from a hidden source.[/quote]
