And, ahem, a code reader.elwesso wrote:at least take your car to autozone for a free alternator CURRENT check.
I did use a K&N for awhile and recently went to a WIX filter.maxnix wrote:No, unless air filter change intervals were abused or K&N filters used (non-OEM), FY33 seldom require MAF replacement.
Heheh, ya, I'm guessin' you found your problem, blind6.blind6 wrote:Pulled my alt tonight and noticed that the intake tube that connects to the MAF on the TB side wasn't fully seated. Could that have been a cause of this problem? Would a airleak cause a faulty reading and making the motor go whack?
It's also a common thing after servicing by the experts....namely the dealer. I posted a long time ago about this. Left Troncalli Infiniti after an intake cleaning and the car was shutting off at stop lights and running like crap. I knew what it was before I even popped the hood. Sure enough, the clamps on the hose were loose.Q45tech wrote:OF COURSE An air leak [after the MAF] will wreck havoc with MAF reading.
A common thing after servicing by non experts......those who haven't had the pleasure of diagnosing one.
I was joking even though we do have a Odyssey. The improper placement of the tube would have been my fault. When I ran into the problem with the TB cleaning was the ;ast time I had the intake out. I must have been in a hurry to get everything back in and overlooked seating the tube. The alternator and battery both tested good. It did take awhile before the problems started, is this a progressive type of mess-up? It was less then a month between the two.maxnix wrote:A lot more Hondas than Q45.
Did you take off or apart your Alternator Idler Pulley? Wrong assembly will cause this noise! This is the one between the Harmonic Balancer and Alt. that the belt rides on! If so this is how it's re-assembled! 1. THREADED ADJUSTER SITS BEHIND BRACKET WITH THREADED PART COMING THREW MOUNTING BRACKET 2. LARGEST WASHER GOES ON NEXT 3. IDLER PULLEY NEXT 4. SMALLER OF TWO WASHERS NEXT 5. CUP SHAPED PLATE IS NEXT 6. THEN FINALLY YOUR NUTblind6 wrote:I've reinstalled the alt and when I started the car up this loud grinding /buzzing noise started comming from the alt. I stopped and readjusted the belts and tried again and it continued to make this noise. Would a belt that has been tightened too much make this noise, or what else could it be? The battery and the alt both tested out good. It didn't make this noise before. The noise increases and decreases with rpm. I have never had so many problems with one car. Were they made to be projects? My 81 Jeep CJ7 isn't this frustrating. Who knows why I'm complaining, I love this car when it's running great.
????blind6 wrote:Is it possible that the bearings were damaged due to this overtightening or does it need to be loosened more?What is the proper slack for the alt belt? It is the OEM alt.
