It looks like the LEDS you rigged up will work for my transmission mode switch as well, both lights for which have been dead for some time. I'll have to try this for the replacements. Great thread, Oz!
ozzie! wrote:I haven't touched my sunvisor lights...But if they ever decide to burn out, I would consider buying some 8 LED festoon bulbs from ebay (white), and pulling the end caps off, soldering on some extra wire and then fit to the holding block.Kinda like these.....
http://www.made-in-china.com/i...s.jpg
Assuming the Q uses that same lamp type for the dome light, you can get a multi-LED dome light from these guys:
http://www.leddomelight.com
I've got one in the Maxima, and I want to get two more for the map lights. The dome light is BRIGHT and a huge improvement over stock. They are more expensive than the ones you linked to, though, but mine has (I think) 12 LEDs instead of 6.They only list 97-01 Q45s on their site, but if it uses the same lamp that those festoon lights you posted are meant to replace, you should be able to use the same ones I've got in my Max for the G50 (unless the G50 domelight lense is significantly smaller than the Maxima's). They're a whole PCB about the same size as the dome light lense with a separate festoon base that you plug in where the stock lamp goes. The PCB has adhesive on the back to hold in in the dome light surround.
Mine's got a slight blue hue to it, but you can get standard white ones as well.
