I forgot to provide the results of replacing my two tension rods with the Revo Racing adjustable ones I got from ebay. My local mechanic installed them but did not adjust or tighten the bolts used to adjust the length of the bars. I then quickly went to Firestone to get a lifetime wheel alignmen and install 4 tires. Since the tension rods are part of the front suspension, the adjusting and tightening of these tension rods are included with the alignment. The ride and handling if firm and the car no longer goes to the right or left when I press on the brake pedals. I will have to wait a few more months to see if the unusual tire wear is resolved by replacing the tension rods. Also, the old bushings looked real bad. These new Revo Racing tension rods has no bushing to wear out. So far I like it. I did not know what to do with the old tension rods, so I threw them away. I also replaced my fan blade, fuel filter, and rubber boots which I bought from
http://www.infinitipartsusa.com/. They have great customer service and great prices.
