Replacing rack bushings on 91 Q45
Q451990
Thanks for the info! In my case I have replaced them just because they're old... no real symptoms...
Heath
off2sobe
Car: '94Q TCS, original transmission @ 230,000 miles
Question for Dennis...
Back in the Yahoo club, you responded in a post about installing motor mounts..."Another interesting procedure is changing rack mount bushings without removing anything other than the rubber and 2 bolts."
Can you elaborate?
Q45tech
Under some circumstances you can feed/work the bushing into the channel with tools [complete field hospital surgical set required] push in, pull the rest of the way around and into place. Lubricant choices.
Make sure all the old oil, ps, ATF, etc is cleaned from channels and leaks have been stopped or the bushings will fail again soon.
