Korben15 »
https://forums.nicoclub.com/korben15-u258265.html
Tue Mar 21, 2017 3:41 pm
Ok, here's the list of issues the dealership says I need to have fixed:
REAR BRAKE PADS GETTING LOW @ 4MM, WARPED $322.16
SES LIGHT IS ON FOR CODE:P2A03, INSPECTED DRIVER SIDE EXHAUST COMPONENTS, VEHICLE HAS AFTERMARKET CATS. NOTICED NO INTAKE OR EXHAUST LEAKS. WHEN LOOKING AT SENSORS VOLTAGES ON C2 NOTICED, AIR/FUEL RATIO SENSOR AND REAR O2 SENSOR NOT FUNCTIONING PROPERLY AT TIMES. RECOMMEND *FIRST* REPLACING AIR FUEL RATIO SENSOR AND REAR O2 SENSOR AND RECHECK AFTER REPAIRS. $956.62
DRIVERS SIDE CAMSHAFT POSITION SENSOR O-RING LEAKING OIL ONTO EXHAUST MANIFOLD. RECOMMEND REPLACING CAM. SENSOR O RING $113.88
SLIP/VDC LIGHTS ARE ON WITH CODES:C1104, C1137, C1185 STORED. FIRST RECOMMEND REPAIRING CODE:C1104. PERFORMED CONTINUITY TEST FOR POWER SUPPLY CIRCUIT, SIGNAL CIRCUIT AND GROUND CIRCUIT FOR DRIVER FRONT WHEEL SPEED SENSOR, ALL READINGS ARE IN SPECS. **FIRST RECOMMEND REPLACING DRIVER FRONT WHEEL SPEED SENSOR AND RECHECK AFTER SENSOR REPLACEMENT** $518.88
FRONT SWAY BAR BUSHINGS ARE BADLY SPLIT AND ENDLINKS HAVE EXCESSIVE PLAY. $348.29
RECOMMEND ROTATE/BALANCE-SEE TREAD DEPTH MEASUREMENTS $100.41
Ok, now the question: How long does changing the brakes on our cars take for all four wheels?
Is the camshaft sensor o-ring easy to replace? I've looked for write ups on this issue, also for the bushings, but I can't find anything. If anyone knows where write-ups are at for these, can you link me please? I have quite a bit of experience with cars and working on them, I'm just not sure how much work it'll take or what I'll have to move/remove to do the camshaft sensor or bushing repairs.
One last thing, how about the wheel speed sensor? Is it difficult to change this part?
Thanks all,
David
