i disagree. the knuckle w/new es bushngs & rlca's alone made a huge difference. then when i stuck my adj. arms & spherical bearings in there was not more rear end deflection & the car is super predictable when stepping the rear out. i say do em all, u got the kit & everything is apart. might as wellnifares240 wrote:The only bushings you really replace are the following if updating all the arms:
frontLower control arms
rearlower control arms and bushings in the rear knuckle.
Don't forget the sway bars bushings, subframe, and diff.nifares240 wrote:The only bushings you really replace are the following if updating all the arms:
good stuff man. thats my next project as well. my left front lca is bent. so im buying a new set from frsports & then gonna press in some black ES poly like you didmaj Andres wrote:Don't forget the sway bars bushings, subframe, and diff.
Yay! I finished the FLCA bushings w/ ball joints.
Burned out the bushing but kept the sleeve (have to) then I went to town on it with a dremel with sand paper attachment. Removing the rubber was such a PITA for me.]Fresh bushings getting pressed in. So easy to install, I pushed them in with my hands.
Feels great knowing that I'm rolling on fresh bushings and ball joints
Next is tie rods and then on to the SPL arms and stance's that I bought in June But not before I slap on that KAAZ that I got coming in the mail...
Modified by maj Andres at 4:57 PM 11/16/2009
i noticed a moderate improvement on turn in w/my peak performance tension rods. but the biggest impovement ive felt was from aluminum subframe collars. the car turns in much quicker now and feels more stable too. there only 60 something bucks and the only downside is the added differential noise, but i dont mind it for the performance those lil guys addDidderson wrote:nice job man. I really want to get my front LCA's done the most... I think it would help my turn-in feel.
they might need to be burned out. im only saying this because most bushings are easier to remove by fire rather than press. you should replace em w/the spl solid aluminum bushigs, thats what i wish i had money for right now.maj Andres wrote:Has anyone replaced the bushing on the differential? the ones that go on the subframe? Do they need to be burned out?
I've read that aluminum rides kinda rough, and I DD my car. I think poly is good enough for me.carps13guy wrote:
I recently swapped a Z32 diff in my s13. It was easier to punch out the rubber bushing, then hammer out the sleeve using a socket (same diameter as the sleeve). It easily came out with a few whacks with a trusty hammer. Not too sure about the subframe ones.maj Andres wrote:Has anyone replaced the bushing on the differential? the ones that go on the subframe? Do they need to be burned out?
Yes, please do so. I envy those of you who have changed out all of your bushings. One day, I'll find the time and courage to do my own. Until then,FlatBlackIan wrote:
I have installed 2 full bushing sets, and I will be doing a third here in the next few weeks. I can do a writeup if anyone wants.
when you have a set of rear knucks/ rear LCA's from your last car that you wrecked it makes it easier... but after breaking a few tools i gave up for awhile LOL im in the same boatS14toRPS13 wrote:
When I did the S14, I dropped the whole rear subframe to make my life easier. The car was in storage for the winter anyway, so I was like why not.Didderson wrote:
Which lip? on the subframe where it attaches to the body or....on the subframe where it attaches to the differential?FlatBlackIan wrote:Just a little tip for everyone when installing bushings. DO NOT CUT THE LIP OFF. Its there for a reason, and without it, you are kind of defeating the purpose of going through all the work.
The lip on the bushing. The one you cut off in your first picture.maj Andres wrote:
Horay for doing a write up to cover all the small details, tricks to use that the rest of these write ups fail to cover.
