koukiKA240 »
https://forums.nicoclub.com/koukika240-u16651.html
Thu Nov 11, 2004 11:16 am
There is a top bracket that has a long bolt that is used for tightening/losening the belt. On this slide bracket there is a bolt that is tightened to hold it in desired place. loosen this and then loosen the belt. Once this is done the alternator should be able to pivot freely from a bottom pivot point. Then get 2 tools on the bottom bolt, loosen it and pull it out. Dont forget to first disconnect all electrical connections. After you pull the bottom bolt out it comes down to fenagling out the alternator from a cramped space.~Sam
