Replaced knock sensor/still error 34/now Crank Angle sensor or E.C.U. problem
aquariustiger
Car: 1989 nissan 240sx
1991 240sx
WELL DECIDED TO MAKE A NEW TOPIC BECAUSE OF NEW PROBLEMS...ORIGINAL TOPIC FROM HERE:
zerothread/274528
Well replaced the sensor but the car stills idles like crazy; even when i'm driving in the highway I can here the engine sputtering..I checked the E.C.U. and it still gives me the code 34(thats the knock sensor) even after I reset the thing.
I bought the sensor from Ebay so don't really know the quality of the product even dough it was brand new..heres the public address:
http://cgi.ebay.com/ebaymotors...:1123
Now when following the instructions for checking the errors from the E.C.U.; I'm following the last two lines of instructions:---------------------------------------------------------------------------------------------------ALL TESTS ARE PERFORMED W/ THE IGNITION SWITCH "ON"
Mode I (Engine OFF)- Bulb Check:
In this Mode, the RED L.E.D. in the and the Check Engine Light stay ON. If either remain OFF, check the bulb.
Mode I (Engine ON) - Malfunction Warning:RED L.E.D. is OFF = OKRED L.E.D. flashes =
For Non-California Models:RED L.E.D. ON = The ECU's CPU or the Crank Angle sensor is malfunctioning.---------------------------------------------------------------------------------------------------
Now when I go check the E.C.U. while I have it on the ON position in Mode I; the red led light stays on all the time; it doesn't flash at all. which instructions clarify the following:
RED L.E.D. ON = The ECU's CPU or the Crank Angle sensor is malfunctioning!
This is where my main question comes in ; I got a hold of a Crank Angle sensor(+some others) from a same model engine as mine( KA24DE) but mines automatic & the other is a Manual-stick. because of this difference does anybody know if this sensor is & ;the others; compatible with my engine? If its compatible is it just an IN & OUT installation???
p.s. I hope its not a bad E.C.U. but if so does anybody know where I can get a use one? This are the numbers on top of the E.C.U. that i could see:
it has a big # 25 ontop & then the following
A11-B45 G08 0x11
I'll try to post a pick for both later for i'm having problems with my digital camera now.
Modified by aquariustiger at 12:23 PM 9/2/2007
redsx13
Car: 93 240sx 03 350z
you have a lot to say but it seems you know your ****. if you reset you ecu, replaced your sensor and your still pulling the code chances are that you MAY need a ecu. i see used ecu's go for cheap all the time on egay. and check nico club for full part outs.
aquariustiger
1991 240sx
thanks dude!; I currently bought this 91 240sx & also own a 89; I just love these little devils...I don't have a garage so cant really do all that i want to; just like to work on them & spin them around!!!
Well as u said; I have replaced the crank angle sensor & timed the whole shi*** and still get that code. I currently removed that air thing (forgot what it called; passenger side, next to the firewall) & will be cleaning it with ur usual carbon cleaner. What a pain in the arssss to remove that thing on a 91; not like the 89 i have.
will also be looking for that E.C.U.....CATCH U ALL LATER & THANKS!
reezn
Car: 2005 G35C 6mt
aquariustiger wrote:thanks dude!; I currently bought this 91 240sx & also own a 89; I just love these little devils...I don't have a garage so cant really do all that i want to; just like to work on them & spin them around!!!
Heres a nice knock sensor replacement linkhttp://www.socal240sx.org/articles.htmlalterna ... =160234ohh and You're talking about the IACV/AAC. Do these have gaskets? I have small idle problem when cold and want to clean them, but worried.
Modified by reezn at 5:11 AM 8/8/2008
Modified by reezn at 5:16 AM 8/8/2008
