knock sensor question
aquariustiger
Car: 1989 nissan 240sx
1991 240sx
hi fellows; i hope u can all help... i own a 1991 nissan 240sx se automatic
i followed advice from some previous topic concerning on how to easily removed the knock sensor.
well the thing is that when looking at the connection going to the sensor i noticed that only one of the female plugs was showing. i also removed the tape around the wire to show everything....its hard for me to explain so i took few pics .... the thing i wana know is if this is normal or somebody did this on purpose for some reason. i just dont want to startup the car and blow the expensive sensor!...any takers???
Modified by aquariustiger at 1:37 PM 8/25/2007
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
thats normal.
the one white wire is the actual signal wire that goes from sensor to ecu.
the other wire is whats known as shielding, and it goes to ground. it made to keep the knock sensor signal pure so to speak, keeps it from picking up voltage staticaly.
thats not the exact definition, but its the best way i can explain it, and hopefully you can understand.
ca18datsun510
by white wire i mean the one thats slightly yellow ish
efrain240sx
Car: 1992 nissan 240sx HB
yup this man ^^^ speaks the truth. I connected the ground to the other pin on the knock sensor and the car went crazy.
Robsx_se
Car: 1991 Nissan 240sx se
sorry for this noob question but i'm trying to learn. what is a knock sensor?
ca18datsun510
it detects detonation in your cylinders and sends a signal to the ecu telling it to adjust the timing and/or fuel ratio.
Robsx_se
ca18datsun510 wrote:it detects detonation in your cylinders and sends a signal to the ecu telling it to adjust the timing and/or fuel ratio.
I love this site. i've learned so much.
aquariustiger
1991 240sx
Well replaced the sensor but the car stills idles like crazy; even when im driving in the highway I can here the engine sputtering..will create a new topic for the following NEW problems:
possible crank angle sensor; thats the thing under the distributer; or the E.C.U. is bad!!!
check new topic here:
zerothread/276276
ANY NEW ADVICE HERE FOR THE KNOCK SENSOR THING IS STILL WELCOME!
Modified by aquariustiger at 12:16 PM 9/2/2007
