Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.html
Tue Sep 17, 2013 3:29 pm
Where do you see it is recommended to replace the outer wheel bearings? Repacking with grease sure, but unless there is corrosion, pitting, scoring, etc when you inspect the wheel bearings there is no reason to replace them. You should inspect and repack the inner bearings too - you will need new inner grease seals for those.
Wagner rotors should be good. I have Wearever (Advance Auto parts house brand) rotors and they have been fine too.
