IanS »
https://forums.nicoclub.com/ians-u23642.html
Wed Jun 06, 2012 7:39 am
Rex hit it square on the nuts.
You will pay more for the part throught the shop, almost no question. Its part of the profit system. The higher part price offsets the lower labor rate a little. Many stealerships are charging $140+ an hour, while indipendants only charge half that. The discount that we recieve from the parts stores is less then you think. Also, remember, you get what you pay for, so the el cheapo part is rarely a good way to go. A good shop will be able to recomend the best bang for the buck as far as part quality is concerned. Also, whenever installing a part into a car, a shop is assuming a certain amount of risk. If the parrt fails prematurely, then the shop will have to replace it, free of charge. Its not the shops fault, but parts companies will not warranty the labor, so the shop gets the shaft.
I wouldn't suggest carrying in a part either, it s like bringing your own appitizer to a fancy restraunt.
If you cant afford to pay the markup, learn to install the part yourself.
