Jemdawg »
https://forums.nicoclub.com/jemdawg-u48609.html
Wed Nov 29, 2006 5:23 am
This is pretty simple. There are only two panels you will have to remove; the middle one on the top of the dash, and then the one surrounding the stock HU. The top one pops right off, it will definitely feel like its about to break, but I assure you that it will not. You just need to get a good grip on it and pull it off starting from the front, a screwdriver should not be necessary for this step. Once you get this panel off, put it to the side somewhere, you should now see two phillips head screws holding the front panel in place, remove them and put them somewhere safe. You can now proceed to remove this panel, there will be two wires holding it in place, you can disconnect the wire attached to the hazard lights, but the airbag light itself must be removed, do not disconnect the wire attached to the airbag light. Removing the light should be self-explanatory; just squeeze the two tabs you see on it, it will take some force, but it will come out. Now you should have full access to the head unit, however, I cannot assist you any further unless you remove the brackets from the HU and take a gander at the wire harnesses plugged into the back of the unit as I have an SL model, not an S model. With any luck, they will be the same as in my car. In any event, do this and take a picture or at least, with elaboration that will suffice for my understanding, describe what you have. If yours is the same as mine, you should have three harnesses, two with multiple wires, on your left hand side of the HU, and one with only two, on your right hand side of the HU. I hope this can help you insofar, I'll be in class for a lot of the day today, so please be patient if you get back to me sooner than my expectations.
