removing radio dash
justinraz
yeah no one really wants to touch it. hopefully within a month or so they will make the new fittings. the subaru plugs are so close but wont work.
Jemdawg
Car: Super Black Nissan Versa 1.8SL Hatchback
What is the world coming to? Audio techs won't even make an alternate solution when there isn't a direct adapter. If they knew how the antenna worked, I'm sure they would figure something out. The only thing that I thought was weird was the second wire attached to it...perhaps that has something to do with satellite pre-wiring, I don't know.
LMS79
Car: 2007 Nissan Vera / Red Alert
Chat with Crutchfield assistant;
SystemJodi. has joined this session!SystemConnected with Jodi.Jodi.Happy Holidays!Jodi.Hi, my name is Jodi. How can I help you today?Ericyes, hi. your site states the item #12040SB30 is compatible with my 2007 nissan versa, yet it says its a Subaru adapter. checking to see if this is true.Jodi.Do you have the 4, 6, or 7 speaker system?Eric4Jodi.Im sorry.. I dont list it as working with that car.Jodi.Our site listed it at working?Ericyes, i put in my car, 4 speaker 07 versa... and it came up under specific adaptersJodi.Im sorry. I cannot promise it will work. I show that we dont have any adapters for that vehicle yet.Jodi.I will have to let our research and web team know.Ericok, thank you.Jodi.You’re welcome. Have a great day.SystemThe session has ended!
pfft... idiots
Modified by LMS79 at 9:25 PM 12/11/2006
Jemdawg
It happens. For example, Best Buy's website said that an amp wiring kit was not compatable with the Versa. WTF, how could a wiring kit not work with a car?
MiXMa5TaMaX
Car: Nissan Versa
I just installed a sweet new pioneer premier headunit in my Versasound quality is great, plus it hooks straight up to my ipod
my only concern is, now, my passenger seatbelt light won't stop flashing, even when the passenger's seatbelt is on!is there an (easy) way to fix this or am I just gunna haveta learn to ignore it?
proxim2020
Passenger seat belt? There's a seat belt light in the instrument cluster and then there's an airbag light to the right of the radio. Which one do you mean?
CodeRed
Car: 2008 Nissan Versa S MT
MiXMa5TaMaX wrote:I just installed a sweet new pioneer premier headunit in my Versasound quality is great, plus it hooks straight up to my ipod
this means you must have unpluged the airbag light, this is a nono you have tom go to the dealer and get it reset for about $95, for some reasion you cant simply reset it by unpluging the (-) terminal from the battery. for you, i think the best bet is to go to the dealer and get it checked out, i could be wrong.
proxim2020
If you are talking about the air bag sensor then you'll have to go into the dealer to have this reset. You should never unplug this unit, but pop the whole unit out. If anyone's thinking about replacing a radio, do a search for Jemdawg's posting about how to do it.
MiXMa5TaMaX
Car: Nissan Versa
noi am refering to the passenger SEAT BELT lightthe one that's right next to the driver seat belt light
the passenger seat belt light won't stop blinkingand the passenger AIRBAG light is fine
I was going to try unplugging the negative battery cable, but I haven't gotten around to it yet
Jemdawg
That is your best bet. A hard reset of the electronics is the first thing you should do when you have a problem like that. It's safe and you won't waste your time trying to fix something that isn't really broken.
