NRGM45 »
https://forums.nicoclub.com/nrgm45-u172771.html
Wed Jan 17, 2018 2:22 pm
I did it with a regular zwave plugin module. Plug that into the wall and plug in a 12V power supply into it.
That way, when you switch on the plug in Smartthings it powers on the power supply to supply 12V out.
Next, hook up a normal automotive 12 V relay to that power supply. Use the other side of the relay to short circuit the buttons on your remote. That's effectively a "dry contact".
Next make your switch for that zwave plug "momentary". There's a custom app that you can load in the IDE that will make any switch momentary. What that means is.. once you push it. it'll come on.. and after a preset amount of time, it will automatically turn it off. I set mine to 3 seconds, since the remote on my remote start takes about a 2 second hold down to start the car.
But yeah... regular zwave plug... 12V power supply (cheap!) and a 12V relay. All done.
