IanS »
https://forums.nicoclub.com/ians-u23642.html
Tue Jun 07, 2005 4:16 am
They are right, the MAFS cannot read compressed air, Ive heard of people with MAFS after the turbo, but never on SRs, another problem will become aparent if you get this set up running, having the MAFS so close to the throttle body will cause deviations in its readings, if you open or close the the throttle body quickly, it will often force air to flow backwards, now normaly the BOV takes car of this, but if your MAFS is so close to your intake its going to read that air, it doesnt know the differance between forward and backward, so air is air, and its going to dump loads of fuel in at odd times causing the car to stumble while trying to do things like throttle lift oversteer, or middrift feathering, it can also happen during quarter mile runs while tring to launch.
