VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Jul 08, 2023 8:50 am
Not sure how the hazard switch comes out, maybe oen of the Z mavens here can help you with that. When you get it loose, jump out G/W~G/R as I mentioned. But before you do that, I suppose it's possible you have a bad "common" contact in the directional switch or a downstream wiring issue. To find out, rig a high-wattage bulb like a headlight to jump between G/B and ground and G/Y and ground at the directional switch. If that slows down the flash rate on the respective side, then you have a wiring issue downstream from the switch. If it doesn't, jump it to LG/B. It should flash immediately, if the rate is normal then the common contact in the directional switch is bad, if it's dim and hyperflashes then you need to check the hazard switch.
