I reiterate, we all have VH or VK series ingines here. In that context (which your extensive quoting was not), neither the less expensive NGK iridiums nor any other manufacturers plug is recommended.Haitian_King wrote:
I did remember. I also referenced the difference in engines.
My main focus was on the benefits of iridium vs platinum plugs.
Dennis, for those who don't understand the phenomena, explain the differences between normal combustion, preignition, and detonation. Also explain how detonation is not always audible even at low RPM/high load, but still damages engine components. Shock loads from detonation can be severe, and affects cylinder walls, pistons, rings and bearings. Note to the uninitiated: If you can hear detonation (ping) it's damaging your engine. If you have detonation, and can't hear it, it's still damaging your engine, just not as fast or as severely, but the damage is cumulative.Q45tech wrote:Most people only hear the mild ping when the accelerator is depressed at low rpms in a high gear as the cruise advance is suddenly too much and the ping [rattle] starts before the ecu can react.
The dangerous ping occurs around >4,000 rpm and WOT which is usually covered up by engine noise!
By the way we have now replaced 2 more Q injectors since last week. This brings the total to 14 since March 1. This is more in 2 months [since E10 availability] than we have changed in 5 years!
I'm not talking about Greg when referencing "who knows who." I'm referencing the person HE talked to. I do think an engineer's opinion is helpful but that's one person, six years ago and who knows what the variables were in this engineer's decision to NOT recommend Iridium plugs. His company sells them and they must have tested them and until we have proof that they are not beneficial and at worst harmful then they appear to have nothing but benefits. More power, less voltage requirements, cheaper than some plugs.maxnix wrote:Who would be Greg Childs, the owner of this board. The plugs haven't changed in 6 years.
Your point is?
*Gasp*maxnix wrote:I reiterate, we all have VH or VK series ingines here. In that context (which your extensive quoting was not), neither the less expensive NGK iridiums nor any other manufacturers plug is recommended.
The head design per se does not determine the fuel type. It is the mean effective pressure within the cylinder that does.
I did not know that about the B plug being the original offering.elwesso wrote:i simply think that the platinum plug reputation speaks for itself. The iridiums arent really that much cheaper and you dont really gain anything by the TYPE OF PLUG.
Thats not to say, you cant gain something by changing the HEAT RANGE! Why do you think the original Q was offered with a 6B plug and then they changed the 5G (hotter).
Ha.........at $4.50 a gallon for diesel, I'm not going anywhere near it. Speaking of outrageous fuel prices, how are most Q owners going to react when gasoline hits $5 per gallon? And don't say it won't, because it will.jimbyjimb wrote:Do a diesel swap. You'll be my hero. Haha, if only I were a rich man...
