M4point5 »
https://forums.nicoclub.com/m4point5-u221045.html
Sun Jun 09, 2013 8:02 pm
I wanted to start a thread dedicated to reducing underhood temps for the M series - more specifically the M45. Anyone who owns one knows that it is like an oven under the hood after driving for any decent amount of time - "heatsoaked" we can say. I can't speak firsthand about the M35 getting as hot under the hood, but any info here can most definitely be beneficial.
First thing's first - heat robs power. Period. You may notice when it is colder outside, your car will feel like it has more power than if it is hot out. Generally, for every 10 degree temperature drop, you free up 1% horsepower. It doesn't sound like much, but let's throw an example out there. Say your car is making 250hp to the wheels at an underhood temp of 180* (who knows if it gets that high but this is theoretical). If you are able to reduce temps by 30* (at the intake manifold), you have just now freed up 3% more power which equates to 7.5hp. So just by reducing your IAT by 30*, you gained 7.5hp. Not bad right?
Aside from the exhaust manifolds, the radiator, radiator hoses, etc. all radiate a good amount of heat. Heat is transferred from the head to plenum and throttle body, thus robbing you of power EVEN IF you have a cold air intake sucking in 70* air from outside. The cold air you are taking in will be much hotter once it hits your combustion chamber - it doesn't matter WHAT car you have. We know this already. So in order to reduce these IAT's, reducing the amount of heat that is radiated will help tremendously.
Thermal wrap or tape on the radiator hoses, radiator heat shield, fuel line insulating (wrap or tape), plenum spacers, throttle body spacers and exhaust manifold wrapping will reduce the amount of heat radiated and held in the engine bay. With the way the M engine bay is set up (specifically the 45), the upper radiator hoses run pretty close to the throttle body. Any heat radiated from the hoses will essentially be trapped under the engine cover and of course cause heatsoak on the throttle body. Being aluminum, that heat transfers to the lower plenum and ultimately the upper plenum.
We want to eliminate as much radiated heat as possible here. I will be providing real-world tests and record them in this thread. I will be using an infrared thermometer to note the temperatures of the radiator hoses, throttle body, upper plenum, lower plenum, exhaust manifolds, etc.
In addition to that, I will then be wrapping all components, adding throttle body and plenum spacers (these are currently NOT mass produced aftermarket, but I am having some made at a local shop) and also getting the upper plenum thermal coated. After this, I will be performing the same driving tests and conditions and recording the temperature results. I know underhood temperatures will be reduced - my MAIN point of wanting to do these tests is to see if the plenum spacers will REALLY reduce temperatures as they are supposed to.
Additionally, I will be getting retuned after these "mods" are done. I have the dyno graph from when my car was initially tuned, so any improvement on those numbers will be the direct result of plenum and throttle body spacers and heat reduction. Further tuning may improve power output as well - we will see.
Feel free to discuss.
