DIDNTSEEMECOMINDIDYA wrote:does anyone know what the actual redline is for the ka engine (DOHC). i havent been able to find it on the net.
corn322 wrote:except that if you go look on the dyno chart in the "AEM EMS Dyno number" thread, the stock hp peak is at 5500 rpm. torque drops off at 5500 as well.
Please stop spreading horrendous misinformation about backpressure. Backpressure is never good, increased backpressure will never help your engine, ever. Also, valves don't push exhaust out, I have no idea where you're getting your information about how engines work. The purpose of the second exhaust valve is to give more exit volume for the exhaust gas to ensure the cylinder is completely (or at least more completely) evacuated. Also, exhaust in your cylinder will only decrease your power as well, why do you think most people bypass the EGR valve?Thee 240sx Owner wrote:and btw.. the reason for the torque drop is the dohc.. the extra valve on the exhaust side pushes more exhaust out which doesnt hold as much backpressure... thats why a sohc has a bit more torque cuz of the exhaust gasses that stay in the cyl
First off, the redline that is on your gauge is there for a reason, its not just some conservative estimate.DIDNTSEEMECOMINDIDYA wrote:the gauge they put in the car is always conservative about the redline. and i hate hondas and will never own one a day in my life.
damn thats weird...all i have is catback and a testpipe on a DOHC and put down 140 rwhp and 142 lbs torque.TogueDrifter wrote:A friend of mine dynoed his S13 SOHC @HP:120 (wheels)TQ:128 (wheels)All he has is the Greddy 3" Cat Back Exhaustand removed the A/C belt... interesting results
then why does the fsm say that all power is measured at the rear of the transmission with all accessories running? there numbers are not crank hp there transmission hp output. and wouldnt there be some loss of power thru the transmission? i would think so. as well as with the differental.Thee 240sx Owner wrote:
Please get a life
Model information:Model code: S13Engine code: KA24EEngine: 2.4L 4 cyl SOHCHorsepower: 140 @ 5500 RPMTorque: 155 ft/lbs @ 4000 RPM
Model informationModel Code: S13, S14, S14aEngine Code: KA24DEEngine: 2.4L 4cyl DOHCHorsepower : (hp@RPM) 155 @ 5500 (crank) 125 @ 5500 (wheels) Torque : (ft-lbs@RPM) 160 @ 3600 (crank) 131 @ 3600 (wheels)
Actually, I was not talking about turbocharging, mostly because that is in no way going fast for cheap in my opinion. Big example of how not turbo a Honda and still be cheap/quick:InsanityInc wrote:Considering you're talking going fast for cheap, I'm going to assume you're talking about turbocharging, in which case you're quite wrong
Unfortunately you said "nissans", not 240s. I guarantee I could buy a beat up 280ZXT or a Z31 turbo and beat the pants off of that setup in a drag race for about a quarter of the price. Also, why are you comparing a built hybrid motor in a car to a stock 240sx?2BN_S13 wrote:Actually, I was not talking about turbocharging, mostly because that is in no way going fast for cheap in my opinion. Big example of how not turbo a Honda and still be cheap/quick:
the B20 Hybrid!B20 crv block + b18 gsr or itr head + b16 short geared transmission = 240 ownage.I have seen this particular setup in action plenty of times, it is quite quick.
Uhh, sorry to break it to you, but Datsun->Nissan was just a name change. Also, by the time the 280ZX turbo was being made, the company was called Nissan, even though it said Datsun on the back of that particular model.2BN_S13 wrote:Well, you are absolutely right about a 280z but that is a Datsun, not quite the same thing. I am refrerring to 240's because we just happen to be in the KA section of the forums and KA24 motors are in 240SX's stock. Aside from the few who actually own Altimas and hardbody trucks, they are the active majority in this tech forum.
Well, with a 10-15% loss do to the drivetrain, that sounds about right...120HP *.15 = 21HP lostTogueDrifter wrote:A friend of mine dynoed his S13 SOHC @HP:120 (wheels)TQ:128 (wheels)All he has is the Greddy 3" Cat Back Exhaustand removed the A/C belt... interesting results
honda hates you tooDIDNTSEEMECOMINDIDYA wrote:first off i do own a 240sx, its a 1993, and the redline they give is 6900. second off the gauge they put in the car is always conservative about the redline. and i hate hondas and will never own one a day in my life.
I think the major thing is, no NA B-series engine make decent torque, not even B20 franks... Even the H22 isn't anything to brag about, and the rarity of a H22 swap is high enough that almost any honda you're gonna pull up to isn't going to have to torque to beat you off the line (granted I think reving your engine at anything that pulls up to you at a stop light is really foolish and a good way to get tickets) and they SURE as hell can't out handle a well balanced RWD car. I totally agree that they're well engineered little demons, but almost any civic you pull up next to with a 4 inch fartbox isn't going to be able to go toe to toe with a 240SX, or almost any other nissan for that matter. It's an econobox, not a sports coupe. (that's why my insurance is so much higher than my mom's Insight)2BN_S13 wrote:Also, I feel the need to mention it because alot of 240 guys think they are unbeatable and fast and blindly hate on hondas without either having worked on them or actually racing a formidable one. I think this whole Nissan superiority thing is just stupid without actually getting your hands dirty on another make.
Yes you are quite right, I mistyped and "240sx" did not make its way into that statement, thusly: "any nissan 240sx" meaning a 240 with a nissan factory installed motor.2BN_S13 wrote:any nissan
I think if you got to switch YOUR cams near the end of your powerband, you'd have a lot of top end too, but the thing is, the cars aren't real well rounded. Topend is great if you're looking to get tunnel vision on some abandon country road but peak HP means close to jack, unless you've got some low end and mid power to get to that point.2BN_S13 wrote:I am aware of the torque differences between Hondas and Nissans, specifically in the KA motor. Handling will never be the same as an S-chassis, but I have personally run some N/A Hondas at the track that deserve praise. Since we are in a redline thread it is totally approprate to bring up these cars that have redlines higher than our own. I dont know if it is the weight difference or what, but these cars with tuning and the basic bolt-on mods can carry well against or beat 1990's 4 cylinder nissans with the similar mods.
