SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Thu May 19, 2005 6:51 am
The ECU's are interchangeable, but that doesnt mean that you should interchange them. The difference between 62 and 63 is that one is a manual, ones an auto. Its the same for the E5 and E6. I tried an E5 on my Redtop and found a slight bogging during acceleration at freeway speeds. The only important difference between the redtop and blacktop ECU's is the O2 sensor, the redtop uses a thin one, the blacktop uses a fat one. And an O2 wire is in a different place on the ECU.
If you want to know how to run a J4 or J5 Kouki ECU on an earlier model S13 SR, then search, I showed a guy how to repin his harness about a week ago in the same forum. The Kouki ECU needs repinning of most of the coilpacks, tach, O2 wiring, and a couple other misc wires.
