Since two months I have a new problem with my car.
Forst I'm living in West Africa, where the temperature never drop below 25°C (77°F) during the day but normally it's always between 30°C and 38°C (86°F - 100°F)
I always ride the car with the AC on at 23°C (74°F) with the recirculation on.
Now it happen every day, suddenly when driving after 5 minutes or less the Recirculation is going off by itself... and I don't know why.... Sometimes it goes off and the AC will turned off at the same time but sometomes the Ac will stay on even the Recirculation is off.
In every case, when the Recirculation is goign off there is no reason because I'm far from 23°C (74°F) inside.
I turned it on again and sometimes the AC will turn on too but sometimes not.... but it goes off often, every 30 seconds... sometimes it's ok it will stay and both are working fine....
I have no idea where to search first.... It's an AC or compressor problem ? I don't think the compressor has a problem, because when working it's really cooling well and quick and there isno strange sound on the compressor side.
Is there a sensor to control the Recirculation switch ?
Can someone try to help me what to check first please ?
Thank you so much in advance.
