VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Sep 15, 2025 7:52 am
Could be a bad head unit, yes. That Intake Sensor signal might be normal, it's measuring the temperature of the evap (the part of the A/C which makes the air get cold). With the A/C active, it should go down near 0C. However, it shouldn't freeze up. If the evap turns into a block of ice then the air can't get through and you lose A/C until you shut the system down and let the ice melt. The usual cause of that (if that's what is happening) is a bad TXV Valve.
