KingTurd »
https://forums.nicoclub.com/kingturd-u68620.html
Sun Mar 30, 2008 4:54 pm
Greetings all. Its been a while.
Anyways, my car (91 with sr20det) was in an accident a while back, and I finally got some time to put it back together. I figured while it was down, I might as well rebuild the turbo--the stock t25. It was burning oil like crazy.
So I bought a rebuild kit from ebay and rebuilt it according to the instructions, keeping note of the balancing. I reassembled everything and got the car up and running. The spoolup was great, sounded nice and made boost seemingly faster than before. Did not burn one drop of oil, which is why I rebuilt it to begin with. It was a complete success.
I drove it around stock psi (pressure source hooked directly to wastegate) for about 300 miles, then I decided to hook up my MBC once again. Well, for some reason my MBC went whack and spiked the turbo to around 15 psi. I thought maybe it was in my mind (heh), so I tried it again--15 psi. So, I hooked it back up to the wastegate directly.
Well, while driving after this incident, the turbocharger would spool up and sound like a siren, almost like a supercharger. Louder with higher psi, etc After doing a little research, I found out that its probably out of balance. This seemed odd because it sounded absolutely fine before that day. So I inspected a little more--turns out that the compressor wheel shaft nut came finger loose! However, it did not come all the way off but it was enough to cause the wheel to spin slightly out of balance.
I disassembled the turbocharger and inspected it a little more. The compressor wheel just ever so slightly scraped the compressor housing. The wheel did not crack nor bend as far as I could tell, but some of the fins were grinded a little bit. So I realigned my marks, loctited and torqued down the nut and everything else, and threw it back on the car. After letting the loctite cure, I took it for a drive again--same siren/howling noise. It still made boost, but the noise just doesnt sound right. It sounded neat, but I knew something was incorrect.
So, I removed it *again* (in record time for me--24 minutes from start to finish, and about 10 minutes to tear it all down). The marks were still lined up properly, and the shaft nut was nowhere near being loose. It still spun freely.
In conclusion, my question is this: Is the siren/howling noise due to the imbalance? Did this maybe hammer out a bearing internally? I did rebuild the entire thing, with new bearing and all. Is this even salvageable? The shaft still spun freely without any hangups, and there was very minute play in the shaft moving it up and down (but not pushing it in and out).
Any information appreciated!Thanks in advance,Brady
