Port matched the upper and lower intake manifold and removed the secondary butterflies. I am waiting on a last few parts to come before the 12th. I have to pull 350$ out my wallet to buy the finishing parts so i will be ready for this spring/summer. Also got a FMIC so i will be running 10psi this season. Cant wait.
Here a list of the parts and prices:ITM rebuild kit(bearings, pistons, piston rings, full gasket kit, oil pump)-260$280z high flow oil pump-90$OEM head bolts-40$
Othe stuffD21 clutch and flywheel-160$JGS MM-118$
Throw in 50$ for misc. thing i got like spark plugs, wires, cap, rotor.
Just on the engine i have 390$ Clutch, flywheel, and MM-278$Misc.-50$
Total-718$ in the whole deal...plus about a 1,200 in my turbo kit.
Got some of the last second parts in. The only thing i am waiting for is the JGS MM but i dont need those until mid next week.spent a few hours working on the motor earlier tonight. I took care of some little things and pretty much finished the engine. I still need to get a pcv line and intstall it but other than the oil pan, alternator, power streeting pump that is about it.
I also finished the bung on the oil pan for the return line. Nothing like a little JB Weld. Used a cheap flux core mig welder to weld it best i could then the jb weld to seal any pin holes that were there.
Packed the transmission mount with some 3m window weld
To finish this off here are a few pics of my car. Finally warm enough i indiana that i could wash my car. I didnt put the side skirts on yet but i have them.
Comments welcome...
Modified by nelson8708 at 3:49 PM 3/16/2007
Modified by nelson8708 at 8:12 PM 3/16/2007
