240sxmech wrote:Well from what it sounds like with the valvetrain noise is that you didnt even break the motor in because if you had you wouldnt have valve noise after the break in. If you didnt break that motor in I feel sorry for you. Hope your bearings last ya, you better pray to the bearing gods, but if ya did break it in then dont worry about what i said and have fun boosting that pig.
That was the first start up. I am still breaking in the motor. I only have 72 miles on it.
I would say from beginning to end it took about 4 months for the rebuild. To tell you the truth i broke it down in about two weeks working on it once a night. Then it took about three weeks to put it back together. I didnt work on it every night though. So spread out about 5 weeks working on it once a night for maybe 45min to a hour over 4 months. As for the clutch i dont know if there is a difference but the truck (d21) clutch is way cheaper. With the d21 flywheel you can run any 240mm clutch if it has the right splines. From what i have read you can run RB series clutches, 300zx clutches, d21 clutches, and even the 280z turbo clutches (also cheap like the d21 clutch). The rumor is that the d21 and 280z clutch can hold a lot of torque.
scared the **** out of myself tonight. On the way home from work i was on the transition ramp from one interstate to another and had to down shift to pass a semi. As soon as i got on it a little the engine started to freak out on me. It was sputtering and everything. So i roll for about a mile and stop on the sholder of the interstate.(I work nights so i couldnt see anything) It was still idleing but just barely. I see some black smoke coming from the tail pipe so i thought she was done for. I pop the hood and see the manifold is red hot agian. So she runs good enought to get to the next exit about a mile away on the shoulder. So i get to the exit and pull into the first parking lot with a light and shut her off. I look under the hood and one of the couplers popped off. I dont know if the motor moved or if i hit a little boost but it was off. So i get it back on and she was still sputtering for a second but after a small rev to 3k to clean her out she runs fine agian. I guess the black smoke was from it running rich when the maf was off. That was a scary night.
