You can bleed the CA hydraulic lifters, progman's analagy is sort of correct.
You can also disassemble the CA hydraulic lifter and clean each one out, then reassemble, I have some info on this that I will dig up from my archives.
If you want to bleed them, you need to submege them upside down in CLEAN oil, then use a coathanger or something to repeatedly push the valve in.
If you find that no matter what you do, you cannot push the lifter valve in, take the lifter out of the oil and let it sit the right way up for 24 hours or so, it will be easy to bleed afterwards.
Back in the oil, when you are pushing the valve in, you will see small air bubbles appear from the pin holes in the lifter, then when the air is gone, you should see the oil swirling with no air bubbles, they will be bled when this occurs.
Do not sit them upside down when finished, my suggestion is to put each one straight back in the head when bled properly.
Hope this helps...
Here is a link to the page on how to pull the lifters apart..
http://twinturbo.net/net/viewm...rch=0
I would suggest copying to a word document for ease of printing
Modified by meminto at 4:37 AM 5/17/2008
