cbh148 wrote:Would you translate all of that into English for me? I'd really appreciate it.
I just put my cams in, but if this is a guaranteed method of preventing lifter tick, then I'll do it.
If you put the cams try it that way if not working then..
I belive theres no guarantes in this things but this is what i learn see the video and read this.
http://www.youtube.com/watch?v=EX5XLh1AFlU
1- Take the lifter in you hand and knock on the table (wood) until "falls" the cilinder in it
2- Drop all the oil in the lifter and the small cilinder
3- Then clean ir with WD40 or fuel
4- Push repeatly the little ball inside the cilinder with a knife / toothpick or someting untill the old oil comes off
5- Clean again the cilinder with WD40 and push it (it has to be soft)
6- Dry with compress air, if you could, to clean it properly
7- Put upside up the lifter and fill with new oil to the half aprox
8- Insert the cilinder in it and push sometimes to mix the oil
9- Repeat this 15 times more
I hope it helps... Salute.
