smokey86678667 »
https://forums.nicoclub.com/smokey86678667-u14517.html
Wed Feb 11, 2004 2:56 pm
Hey, I have a friend that breaks in all of his talons like this and his latest one makes 550 at all four wheels.
First he starts the car and lets it warm up to operating temp. then shuts it off, lets it cool down completely, and repeats the process one more time. After it has cooled the second time, start it and let it warm up one more time then drive it around the block. While your driving it, start accelerating (NOT WIDE OPEN THROTTLE, YOUR NOT LOOKING TO BUILD BOOST OR JUST RAISE H***)and bring it all the way up to around 6,000 rpm or so(WHAT EVER IS ABOUT 1,000 RPM AWAY FROM REDLINE FOR YOU) LETTING THE transmission SLOW THE ENGINE BACK DOWN. Do that a couple of times and your done, just drive it normal. He does it with all his and he swears by it.
As far as the clutch I always use an ACT 2100 6puch, but I now someone with an awd talon that has an exedy and he has put probbably 5,000 miles on it and it holds up good.
Thanks, Ben:)
