rear toe rods required when slammed?
casman86
Is there enough toe adjustment on the eccentric bolt on the factory toe rods to compensate for the toe-in when slammed on an s14? I obviously have a lot of toe-in on my s14 after putting the coilovers on, and I would prefer to use the stock rods if possible. Let me know. Thanks.
tramp_drift240
Car: 1992 240sx SE Coupe
aint crappenin'
youre gonna have to pick some up, theyre pretty cheap. ive got megan adjustable toe rods in the back and it fixed my toe problems after the coilovers.
casman86
Well, today I slotted the holes on my stock toe rods to bring the toe back into the adjustability range. I slotted the holes 3/16in. and it looks pretty good. I guess I'll know once I bring it to get aligned if it really worked, but eyeballing it there is a world of difference. If it doesn't work I'll just order some toe rods.
tramp_drift240
as long as everythings safe, i dont want you to be cruisin' and have the stock ones snap or something due to drilling out the hole...
good luck widdit
moulton712
Car: coupe, hatch, both s13s
tramp_drift240 wrote:as long as everythings safe, i dont want you to be cruisin' and have the stock ones snap or something due to drilling out the hole...
good luck widdit
your starting to play with being safe
imbrognolouis
Car: 1994 240sx vert and 2000 dodge avenger
i got a s13 but the second i put the kts' on i couldn t get toe in. i'm about .20 outa spec fully adjusted. I got some new rims/tires looks like i'm investing in some aftermarket toe rods
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
These guys are indeed correct. To have enough adjustability to set proper toe, you will need aftermarket toe arms. I would personally buy SPL.
Oh, and I moved your thread to the correct forum.
casman86
Unsafe? They are factory. Chinese aluminum suspension arms with cheap pillowball ends are unsafe. Those actually do break.This is awesome if I managed to slot it the correct amount.
Modified by casman86 at 9:00 PM 4/5/2008
duffman1278
Car: 89 240sx Hatch, the wildcats!
SPL is NOT chinese made crap parts. Their probably the best suspension arms available right now.
adrianfromthecastle
Car: 1992 Nissan 240sx
duffman1278 wrote:SPL is NOT chinese made crap parts. Their probably the best suspension arms available right now.
I gave my suggestions in this thread zerothread/327468
