Agreed with that.CJH wrote:You just need to roll your fenders
Lol neglect? It's probably the most taken cared of 240 in New York.mechanicalmoron wrote:Poor car. Worse than neglect, it's active destruction.
So you're saying thee new struts I ordered won't help with the bounce? Also is it safe to say it's probably not the springs but perhaps the added drop has blown my rear struts? I will roll the fenders anyway can't hurt.CJH wrote:Youtube it. That's how I learned, by watching some Japanese dude do it to a pink S14. There are many videos for it though. In simplest form, all you need is a hammer. Take the wheels off, pull out any plastic liner you have. Then take the hammer and tap the little metal lip up and out of the way. If you need to roll out the fender at all, then you need either a fender roller, or a baseball bat. It depends if you want to do it nicely, or ghetto-fabulous.
Yeah, with it's knock-off wheels, rubbing on stuff because of the blown struts, stuck into ebay lowering springs....Mr240dude wrote:Lol neglect? It's probably the most taken cared of 240 in New York.mechanicalmoron wrote:Poor car. Worse than neglect, it's active destruction.
Are you entirely sure that they're rubbing? like, you say shredded, so have you found the shredded part of the tire? Perhaps the tire is deforming on bumps, and shredding against the spring, due to offset? (in which case, you should obviously space the wheels)Mr240dude wrote:I didn't know XXR's were knock off *sarcasm*Secondly since when does wheel brand decide the care a car receives? I rather have those wheels with a clean KA under the hood compared to the guy next to me with $2,000 wheels and a crappy maintenance history. Of course suspension and all that comes too but without a running car it's all pointless. That's why I'm here on this forum to address the issue so where is the neglect you speak of? Perhaps purchasing those ebay springs wasn't the best idea but if push comes to shove I will replace those as well.
Sure lets see the horrific pics.pepesilvia wrote:a buddy of mine had an eastwood fender roller so i let him roll my fenders for me in a cold garage.... HUGE mistake, now its a bondo and rusty mess... please get a professional.... ill take some pictures of the result if you'llike
Yes the actual tire wall is starting to look like shredded cheese. You can actually pull some strings of rubber like pollyo cheese. It's getting annoying and you can actually small the tires whenever a bump is hit. As I asked prior is it perhaps the s*** springs being too bouncy or shall I see what those new struts do?mechanicalmoron wrote:Are you entirely sure that they're rubbing? like, you say shredded, so have you found the shredded part of the tire? Perhaps the tire is deforming on bumps, and shredding against the spring, due to offset? (in which case, you should obviously space the wheels)Mr240dude wrote:I didn't know XXR's were knock off *sarcasm*Secondly since when does wheel brand decide the care a car receives? I rather have those wheels with a clean KA under the hood compared to the guy next to me with $2,000 wheels and a crappy maintenance history. Of course suspension and all that comes too but without a running car it's all pointless. That's why I'm here on this forum to address the issue so where is the neglect you speak of? Perhaps purchasing those ebay springs wasn't the best idea but if push comes to shove I will replace those as well.
Because you replaced your wheels with stock sized wheels, if you had bought a knockoff brand to get something different, I would understand more - but, It shouldn't matter how wide they are, as long as they're not hitting the springs, they should NOT be hitting the fender with that drop and diameter, I don't think. Stock 240s are reallllly high off the wheels.
But don't listen to me, simmode knows his wheels to a disturbing degree, from what I've seen.
simmode1 wrote:OP, It might help to get more specific about your setup. You said you have 15" XXR's. But what are the width & offsets? You said you have 205 width tires, but what aspect ratio are they?
I'm gonna guess... There are probably 15x8+0 XXR 002's wrapped in 205/50/15 tires? If I'm right, without coilovers or the ability to adjust your camber, the wheels/tires are probably sticking out from the fenders the all mexi-flush. So when your springs compress under hard cornering & riding over bumps, the car is coming down too low & the fenders are coming into contact with the tires.
The reason why your car is dipping so low in those situations is likely because your bound/rebound tendencies are messed up, from likely blown struts. Really stiff springs can accelerate the wear & tear of old struts/shocks & make them blow faster.
There's a few ways you can solve this:
- Get another set of wheels with a higher offset.
- Stretch a skinnier tire onto the wheel so the curvature of the rubber will avoid the fender.
- Roll & pull your fenders paired with stiffer suspension so the car doesn't go so low under compression.
- Get coilovers & RUCA's so you can dial in some negative camber so the tire will tuck in & avoid the fenders.
Here are some examples of other S13's fitted with low offset 15's. Take a look at their setups:
http://www.rimtuck.com/search/thumbnail ... ameterf=15
Personally, I'd say be extremely careful when driving and just suffer through to blown struts & crappy springs until you've saved enough money for a used set of coilovers & RUCA's, then roll your fenders. Stop by the used tire shop and pick up some cheap 15's if you have to.
