Cpt_Impossible wrote:This is what I did. Make a template out of a big piece of cardboard. Then take a piece of wood (I used particle board) and trace it on. Cut it out, shave as needed. Mark 5 or six holes in the rear wall onto your board so you can mount the thing. Get some generic grey carpet from schucks or autozone or some place. Stretch it over, staple it on (I did front and back). I would recomend using some spray on adhesive as well since mine has sagged slightly over time. Then clean the carpet from the holes and mount it with some bolts. I used wing nuts on the trunk side so that it was easier to do alone.
Ive always wanted to do somthing like this, being as my rear seat is useless due to the harness bar, Ive just been too lazy to remove the rear seats or anything like that, I like the particle board idea because of the noise canceling.
