Rear piston wont turn
josho
Im attempting a brake job on my 93 Silvia. The right side went very smooth but when I went to the left side, thats when the problems started. For some reason the piston will not twist in. I got it to come all the way out, it just wont go back in.....at all!! A buddy of mine said the caliper is shot.? Anybody have some experience with this?
P_856
Car: s13
Is the hand brake down? both of mines turned pretty easy with some elbow grease and some wd-40 i was using needle nose pliers too
zenki-S13
Car: 1990 Nissan 240sx S13
take needle nose pliers and push and twist. use your streanth. it will go in
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
If the piston wont retract, then the caliper should be replaced. It may be jammed, or more likely, hyper extended. Its a common problem with older calipers with integrated emergency brakes.
josho
Yeah, the e-brake is down. I could twist the other side with my hand, but not the left side. I hope I dont need to replace it. Ill try some more tomorrow
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Did you use a brake piston tool?
josho
Nope. Would an auto parts store have one or is that a special order tool?
asoomal
Your local auto parts store should have it.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Once you pop out the brake piston you might as well replace the whole thing because you are going to need a new seal and everything (brake caliper rebuild kit).
TheRealNap0le0n
Car: 1998 q45
POGS!!!!!
yea replace the brake caliper on your silvia... jst make sure you get the JDM caliper as the USDM ones are different
chukidrifter420
Car: 91 240sx
yeah, smae thing happened to mine, replace it, i ruined my brake tool by trying to force it in...then again it was a cheapo but even a clamp couldnt get it back in.
asoomal
This is what you're using right?
masterdisaster
Car: 1991 JDM 180SX
TheRealNap0le0n wrote:POGS!!!!!
wooo .. are you sure about that?!?! .. i never noticed a difference on my 180sx
TheRealNap0le0n
Car: 1998 q45
asoomal wrote:This is what you're using right?
theres an awesome one with interchangeable ends and a big plate and threaded rod to help compress the piston as well
josho
Yeah thats the tool. I bought it and it twistd in just fine. So then I moved on to the front brakes.......Ive got TT300zx front brakes on it. I pressed in 3 pistons and for some f'ing reason, the last one wont go in. Anybody wanna buy a Silvia??Nah, just kidding. I did'nt have all my tools with me so tomorrow im going to take a c-clamp and try my luck with that.
ZOMG.SR20
Car: 1990 s13
dumb question but did you take the cap off of the master or are you cracking the bleeders?
josho
I opened up the bleeder vavle hoping it would relieve pressure but it did'nt work. Should I take the cap off the master cylinder then press it in??
TheRealNap0le0n
Car: 1998 q45
you shouldnt have to do either.... that being said, if you cracked the bleeder and it didnt move you sir have seize caliper..
josho
Well thats bad a**!!! Thanks guys. Gotta get her going before Spring Fling.
safin
WTF
ZOMG.SR20
Car: 1990 s13
^ greatest brake tool ever invented for calipers with integrated parking brakes
koukidreamz
safin wrote:
WTF
Brakubiks Cube
koukidreamz
ZOMG.SR20 wrote:^ greatest brake tool ever invented for calipers with integrated parking brakes
The one RealNapoleon mentioned pwnz the brakubiks cube
ZOMG.SR20
Car: 1990 s13
Razi
Car: Moo
I just used my pliers. :P
koukidreamz
OMG yes I just came. Haha jk, yea thats the one, I have one and its saved my a** more times than I care to mention
