But your exhaust pipes will be much more managable than your turbo 5 minutes after shutting down. The pipes have a great deal more surface area than your turbo does. As such, it sheds a great deal more heat.WDRacing wrote:You don't lose near as much heat/flow as people assume you do. Once those metal pipes heat up, they stay hot for a long time. Ever try to work on your turbo after you started the car for a short 5 minutes? You get burned every time.
Backpressure will be higher with a smaller turbine as airflow through the engine increases. The limitations of smaller turbines doesn't change with location.DrifterProdigy85 wrote:The lack of heat makes for less exhaust velocity which can cause lag with a larger turbine housing. But with a small housing it will raise the velocity making spool similar to a conventional setup and won't have the backpressure issues.
An external wastegate will help with the flow. Not to mention people use T25's for low boost on their KA's already for 8 psi. An additional 38mm's will be more then enough to reduce any restriction.C-Kwik wrote: Backpressure will be higher with a smaller turbine as airflow through the engine increases. The limitations of smaller turbines doesn't change with location.
A wastegate only diverts flow when enough energy is available to have reached the desired boost level. Before then, the flow is still restricted. Still, smaller turbines are less efficient at higher flow rates requiring a lot more pressure differential. To achieve the higher pressure differential, the wastegate stays closed placing more backpressure on the motor.WDRacing wrote:An external wastegate will help with the flow. Not to mention people use T25's for low boost on their KA's already for 8 psi. An additional 38mm's will be more then enough to reduce any restriction.
Exhaust gas velocity will vary throughout the exhaust system and will do so primarily with the conditions present at each section of pipe. When a passage narrows, the gas speeds up. If it gets wider, it slows down. But instantaneous flow through the entire system will be somewhat constant for the engine's airflow. But the velocity is not constant.DrifterProdigy85 wrote:The exhaust velocity changes over distance, pipe size, bends, and heat.
Exhaust gas velocity will not be affected by distance in that of itself. For any given volume of gas flowing through a pipe, the velocity will be dependent on the rate at which the gas flows. The heat loss of course will affect velocity. Bear in mind though that none of the velocity in the pipes are relevant to the operation of the turbo (I'll explain below).DrifterProdigy85 wrote:Placing the turbo at the rear will see alot less velocity from the distance and heat.
No. Velocity is the effect of higher flow (for a given pipe size). And flow is the result of a pressure differential. Backpressure is merely the pressure measurement of the flow restriction.DrifterProdigy85 wrote:Backpressure is caused when the exhaust velocity reaches so high that it builds up creating pressure which becomes the restriction.
I can get just as much exhaust gas velocity out of a small motor as I can a large motor. All I have to do is put in the appropriate pipe size. What a smaller motor can't do is have as much flow (assuming same VE and peak RPM) as a larger motor. That said, larger motors have an advantage as the higher flow rate of gasses allows both high velocity AND more mass. Since Kinteic Energy is equal to (Mass x Velocity^2)/2, if both motors are generating the same amount of velocity for their respective systems, the engine with higher flow will still be outputting more exhaust energy as there is more mass of the gas.DrifterProdigy85 wrote:Sizing the turbine housing is what balances the distance and loss of heat. The larger the engine, the larger the turbine housing will have to be because the larger engine has the ability to put out alot more exhaust velocity.
Assuming you are talking about the A/R ratio, its not a larger housing. The only thing the A/R changes in a given turbine family and trim is the oriface that the gas passes through just before it hits the turbine wheel. Changing the size of this orafice (or nozzle) is what controls the velocity of the gas for a given amount of flow. Simply put, you have it backwards. You don't run a larger A/R to deal with velocity. You run an A/R appropriate to the engine (with consideration of the turbine wheel size itself) to achieve the ideal gas velocity for that turbo.DrifterProdigy85 wrote:Thats why a .60 turbine housing might work on a 2.4L but when you go to a 3.0L, you will need to step up to a larger housing because of the increase in velocity.
To achieve similar spool rates, yes, a lower A/R is necessary. But lower A/R's flow less which makes them bigger restrictions. Smaller turbines are also generally less efficient at higher flow rates. Larger turbines, once in their operating range of flow can work with smaller pressure differentials across the turbine. This ultimately means less backpressure, which means the motor is diverting enrgy that would be used to accelerate the car into pushing the exhaust gas out of the cyulinders. Furthermore required engine airflow rates aren't going to change so matching a compressor to the motor isn't going to change. The smaller the turbine, the more limitations you have on available compressors. You can't exactly get efficient operation by trying to couple a T66 compressor with a T25 turbine. Hell, even something as common as a T04E would likely be too big with anything less than a T3. Basicvally the compromise between fast spool and ability to make more power becomes more of an issue with a rear mounted turbo.DrifterProdigy85 wrote:Rear mount setups need a smaller turbine housing period. The size needed is gonna be based off the engine size and setup.
While a larger wastegate can flow more, if nothing else changes, the turbo will still require the same pressures to operate. The wastegate will still only divert enough of the exhaust gas to maintain the pressures needed to maintain the desired boost level. If the wastegate diverts more of the gas, the turbo won't be able to boost as much. I can't think of any way that this would not be true assuming both wastegates are able to flow enough air to prevent boost creep.WDRacing wrote:People have added larger external wastegates and made power because it increases exhaust flow. Can't argue fact. Just like a smaller turbo will be restrictive, a larger wastegate will flow more.
No, because for a given engine airflow (which implies a specific engine RPM at WOT), the turbo will need a certain pressure differential in order to maintain the desired amount of boost. This is independent of the wastegate. So a wastegate will bleed off enough air to hold the pressure differential. To do this, regardless of wastegate size it needs to bleed off the same volume of air as the volume of the exhaust system before the turbo remains constant.WDRacing wrote:If the turbo reaches 8 psi at 3000 rpm (generic numbers), then the wastegate opens so that the increased exhaust flow created with more rpm has somewhere else to go. There by keeping a semi consistent and constant back pressure. Assuming the compressor is efficient enough to produce plenty of volume. Wouldn't the larger wastegate be able to reduce the added back pressure created by using a smaller turbine flange? That way you can use the smallest flange possible to reduce as much lag as possible.
This is part of the limitation I was referring to. Big mismatches in compressor and turbine wheel sizes will create a slip loss. When this occurs you actually end up with a laggier turbo:WDRacing wrote:Noting that this method is NOT best for a max power type build. But for a lower power goal, say 300whp, if you used a GT2876R or whatever T2 flange turbo that comes with a T4 compressor, you'd have more then enough flow from the compressor side and way less lag from the T2 flanged exhaust housing.
Just my thoughts on this type of thing. Why add lag?
The energy demand of a turbo is ongoing. Its not a once its spooled, it stays spooled type of device. Energy is constantly required to continually compress air. That said, in order to extract energy from the exhaust, a certain amount of air is needed to flow through the turbine. How much depends on the amount of energy needed and is facilitated by the pressure differential across the turbine. The wastegate controls this pressure by bleeding off air. How much air it diverts will be the same for a given turbo, regardless of the wastegate size (excluding a maxed out wastegate). A larger wastegate will simply not open the plunger as far, as the wider area will allow more air through.WDRacing wrote:At the point where the turbo becomes a restriction to total flow, having a larger wastegate will move more exhaust. The turbo already has all the exhaust energy it needs to spin the compressor fast enough to achieve the desired boost. So it's up to the wastegate to bleed off the excess back pressure. A smaller hole won't move as much as a larger one.
Because you're explaining it.WDRacing wrote:How does this not make sense?
We can both agree that we both miss 480sx. But he would agree with me on this as well.WDRacing wrote:We can agree that I'm right
No one does point counter point like you buddy, cept maybe 480SX. I miss that dude alot.
This very well could be. But that just means I'm right, but have failed in my explanationC-Kwik wrote:
Actually Nate and I had discussed this very topic quit a few times. Which is why I miss him right now because he sides with me...for obvious reasons.C-Kwik wrote:
You really don't under stand turbos as well as you think.WDRacing wrote:At the point where the turbo becomes a restriction to total flow, having a larger wastegate will move more exhaust. The turbo already has all the exhaust energy it needs to spin the compressor fast enough to achieve the desired boost. So it's up to the wastegate to bleed off the excess back pressure. A smaller hole won't move as much as a larger one.
