Edit to add some links I had looked over:
1. aligment-shop-full-of-dummies-or-just-me-t605040.html
2. spc-camber-kits-2006-2010-m35-m45-t597367.html
3. official-suspension-thread-t503080-30.html#p6692534
I recently rotated my tires and noticed that the rear ones had excessive inner edge wear. Bad camber. It was negative 1.6 degrees on both sides.
The last person that touched my alignment was the dealership, and of course the numbers were acceptable then. It's possible that my suspension has worn so evenly, but I'm thinking more likely their machine isn't the greatest (I had to go back 3 times to get "acceptable" results)
After getting my new tires I went to Firestone and bought their lifetime alignment package, currently on sale for $162 after taxes, usually $200 before taxes. For comparison, the dealership standard alignment rate is $140.
So Firestone tells me they can't correct my camber. It sounds like my eccentric bolt is seized in the bushing sleeve. Apparently, after turning it to spec, they tighten the nut and they can see the bolt turning back to its original position.
Assuming the shop was actually doing everything right, I need to make moves before I chew up my new Continentals.
I want to buy an SPC camber arm with the turnbuckle adjustment, but I see they are normally sold with the toe adjustment bolt. SPC 72260
I understand that most times people that do this are lowered, but I want to remain at stock height. Here is what I'm curious about:
- Has anyone run out of Stock toe adjustment due to the aftermarket camber arm?
- For those using SPC specifically, did you use the curved arm or the straight one? It doesn't seem likely, but I have to confirm that the straight piece they offer has no interference with other parts down there, right?
