KnifeForkDriver »
https://forums.nicoclub.com/knifeforkdriver-u127801.html
Fri Mar 06, 2009 11:42 pm
Back on subject...
Can anyone confirm this?
Maybe someone who has an S14 with Z32 aluminum rear spindles could chime in? Does the S14 rear ball joint match the taper of the Z32 conical spacer? If so, that answers my question.
All S13, Z32, R32 all have the same rear ball joint (same RLCA too). S14, S15, R33, R34 all have the same rear ball joint (same as front ball joints in case anyone was wondering). Anyways, the only difference I can find is the size of the casing. S13/Z32/R32 rear ball joint is 38mm. S14/S15/R33/R34 rear ball joint is 41mm. Other then that, I believe they are the same, meaning same taper. Can anyone confirm this?
