Really Weird Sr problem
srnate
Car: 90 180sx
i have a redtop 180sx and every time i under 3000 rpm and give it have trottle the engine sputters or surges and shakes the car untill it hits 3. If you ease into it up to 3 it wont do it same if u barry the pedal only half and 3/4 of the ways down. Its really puzzleing. As soon as it hit 3 it pulls so nice and clean all the way to redline any help will be great.
GoTRicEo0
Car: Slowest crap the earth have ever seen.
Check every ground wire. That happened to me awhile back. Turn out to be a big boost leak/cut ecu ground. Hope that helps you
-Jeff
Edit~ Ah I forgot to mention check for boost leaks lol.thx V
Modified by GoTRicEo0 at 9:31 AM 2/21/2008
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
GoTRicEo0 wrote:Check every ground wire. That happened to me awhile back. Turn out to be a big boost leak/cut ecu ground. Hope that helps you
-Jeff
Check your vacuum lines, check for boost leaks, check you ground straps.
