Really Odd Power Window Problem (3 out of 4 windows don't work) [SOLVED - master switch]
jkbrad11
Car: 2009 Infiniti M35S, 2008 Nissan Frontier Crew Cab
Intro: New M35 user.. just got a 2009 M35S , all four of the door actuators were shot so I got it at a great price.. had it a few months now and just now getting enough free time to work on it.
So, I replaced the driver's side door actuator yesterday. After doing so, the only window that works (power, rolls up/down) is the driver's side window.
I've tried a battery pull for 30 min - no luck
I've tried rolling down the windows with the remote - no luck
Put it on a machine and it's throwing the following codes: U1000 U1300 U121F U124E U1254
Cleared them and they didn't come back..
I don't understand what would have happened.. the Switch that is attached to the door panel obviously just plugs in, so i wouldn't imagine there's too much that could have gone wrong there? All four were working fine earlier yesterday...
I've searched everywhere i can't find anything.... does anyone have any ideas?
Reason: Updated title
Ilya
Welcome to the forum.
That's an odd problem indeed. Have you had a chance to investigate the FSM (factory service manual) which can be found in the link in my signature (FAQ)? Might help you out.
Brando C
Car: 2007 Infiniti M45 Sport
Have you tried to do a manual "Reset" on the windows? On my last vehicle, I couldn't get any window to roll down, if I didn't do a manual reset on the driver's window. After resetting the driver window, you had to resewt them all individually, and then they would all auto up/down, and powere up/down. There is a way to do it, and I am sure there is a thread dedicated to it on here. I would try that, and see if you have any luck. If I find a thread, I will link it.
EdBwoy
I had wanted to recommend a window reset, but thought that wouldn't work since the windows weren't moving at all.
This is new to me too. Did you get Brando's old car? Haha
Let us know if that suggestion works for you. The reset procedure:
auto-up-windows-not-working-t498982.html#p5677601
jkbrad11
I’ll try the reset. Of course, all I can reset is the driver side one. But maybe what Brando says will hold up on this car too!!
Yeah I’ve looked extensively at the factory service manual and it’s not much help.
jkbrad11
Brando C wrote:Have you tried to do a manual "Reset" on the windows? On my last vehicle, I couldn't get any window to roll down, if I didn't do a manual reset on the driver's window. After resetting the driver window, you had to resewt them all individually, and then they would all auto up/down, and powere up/down. There is a way to do it, and I am sure there is a thread dedicated to it on here. I would try that, and see if you have any luck. If I find a thread, I will link it.
What process did you go through the 3 second/10 second / 15 second thing? Or something else. I’ve tried resetting the driver door and the sunroof and they’re fine and do their auto open close as they should . But, I still can’t get the other 3 to move...
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
The only thing all 4 windows have in common with the drivers door lock actuator are that they all have a master control on the drivers door along with the lock out feature. My guess is that when installing the actuator, you've either created a short for the common ground for the window controls or the master lock out. If I remember, even when the master lockout switch is enabled, the driver can still control their window. I hope that helps.
Brando C
I just went to each window and did a manual reset. After they all reset, it is like the master switch on the driver's door reset as well, and everything was fine.
bluedevil30
Car: 2009 M35X
265,000 miles
I have a door actuator problem on my 09 M35. Sometimes they all work sometimes only some work (random). I think its a power issue but I haven't had it diagnosed yet. The big problem is your alarm goes off if you open a door that didn't lock when you wanted it too.
kmiles
Sold - 2007 M35x
I had been fighting a door actuator problem, too. It started with the drivers door not working intermittently and then starting in April got progressively worse, and the rear door on the drivers side started to act up, too. I bought a new drivers door actuator online and had a local repair shop replace it. $375 total vs. the dealer quote of $750 per door. Since replacing it, I haven't had a single problem with the rear door in over a month. I thought it might be a wiring problem or ground problem, too. In may case it was a bad actuator.
jkbrad11
UPDATE: apparently it was the door switch. I can only assume I damaged it when pulling the thing apart. Oh well, at least it has been resolved! Thanks for all your insight and help!
EdBwoy
Thanks for the update. Another one for the library.
MikeLarrym35
Car: 2008 infiniti M35x
jkbrad11 wrote:
Thu Jun 22, 2017 3:28 pm
Where did you buy your switch? how much did you pay?
