Auto up windows not working?
SammyTheBull
Car: 2006 M35 Sport
I replaced my battery this weekend and when I was donr the auto-up feature stopped working. The auto-down feature still works..........but not up :confused:
Any suggestions?
FNAWSM
Car: Diamond Graphite '06 M45
oddly enough someone just asked about this exact same thing about 2 days ago, in fact its like 10 posts down from this one. This should fix your problem.
This is form the manual.
If the windows do not close
automatically
If the power window automatic function
(closing only) does not operate properly,
perform the following procedure to initialize
the power window system.
1. Push the ignition switch to the ON position.
2. Open the window more than halfway
by operating the power window
switch.
3. Pull the power window switch and
hold it to close the window, and then
hold the switch more than 3 seconds
after the window is closed completely.
4. Release the power window switch. Operate
the window by the automatic
function to confirm the initialization is
complete.
5. Perform steps 2 through 4 above for
other windows.
does not operate properly after performing
the procedure above, have your
vehicle checked by an INFINITI dealer.
Hope this helps, you may want to check and see if your moonroof is opening properly as well. If not then there is a procedure for resetting that too.
azeiler
Car: 2006 Infiniti M35 w/Luxury Package
I just did this a few weeks ago. After I did the windows, the sunroof worked without having to do anything else. It's a miracle! :laugh:
Kleikamp
Car: 2006 M35X Liquid Platinum
Experienced this myself today. The fixed worked perfectly! Thanks for the post!
M35xPA
Car: 2006 Infniti M35x
The instructions worked great for me, thanks! My driver's door now goes auto up finally.
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
Mod can you add this to the FAQ if not already, seems like its one of those things we tend to forget about
font976
Car: 2007 M45 Sport
I just did this to fix driver side passenger window and it worked perfect. Thanks.
Blackzilla
Car: 2007 Infiniti M45, 2014 Mazda 6
thanks for this! auto up stopped working when i installed the Grom thought i was screwed. man do i love forums
Ilya
You're welcome, heh.
boee
Car: 2013 Infiniti M37x
This tip worked on my 2013 Infiniti M37x, on all the windows, when automatic up was not working. Now automatic up and down work on all the windows. The same tip is mentioned in the Infiniti Owners Portal as well, but it's not obvious for automatic up.
TreyhunnaM37x
Car: M37x
:wtf2: all his time I just assumed it only did auto down and not auto up. Randomly stumbled upon this thread searching for if my 13 m37x just didn't have this feature! Power of the Internet!
Nismoowner66
Car: Gtr
[youtube]https://youtu.be/ZWAj0rEL5u8[/youtube]
Nismoowner66
Car: Gtr
[youtube] https://youtu.be/ZWAj0rEL5u8 [/youtube]
