driftking91 »
https://forums.nicoclub.com/driftking91-u44233.html
Mon Sep 03, 2007 5:09 pm
I have poissitive to possitive and negative to negative. The alternator has the large plug which you cant mess up and a small black ground that bolts on to the back of it. The wire giving me trouble is the third a thick white wire that bolts on to the back of it. Everything works great on the car it runs smooth after a good charge to my westco battery, but as you can guess battery drains after about 10 miles or so. If i connect the white wire and then try to reconnect the possitive terminal on my battery its as if i were welding it on it even wants to melt away the battery post itself. As for the grounding Im going to try and do new negative terminal lines tommorow ill let you know how that went. Thanks for your help. Let me know if you can think of anything else.
